cam chain tensioner.
Old Feb 1, 2011 | 03:45 PM
arab's Avatar
Registered Users
Default cam chain tensioner.
hi, ive just started my cbr 600 fs1 after the winter and its making a funny noise, (like a scraping noise) its done 29k, i spoke to my pal and he said it could be the cam chain tensioner, anyone help ? p.s. is this a big job. thanks. also i give it a run out and noticed the little gear thing that shows you what gear your in wasnt working, it was just spinning in circles.
Old Feb 1, 2011 | 09:50 PM
tripicana's Avatar
what year bike do you have? gear selector thing?
cam chain tensionsers are easy to change. two 8mm bolts and a gasket, 10 minutes tops.
but, cam chain tensioners usualy cause a rattle sound, not really scraping...
Old Feb 2, 2011 | 07:51 AM
arab's Avatar
Registered Users
its a 2001/51, it probably is a rattle, is there any link to pictures to do this. ive had a mind blank - the gear thing is the little l.e.d. display that tells you what gear your in. thanks.
Old Feb 2, 2011 | 09:54 AM
Monkeh's Avatar
https://cbrforum.com/forum/how-mechanical-40/how-change-your-cctl-pics-116975/
Old Feb 3, 2011 | 04:29 PM
tds94probe's Avatar
Replacing the tensioner will only solve half of the problem, if that is in fact what it is. The tensioner pushes on a slider, that rubs on the cam chain, if this gets worn too much, it will need replacement as well.
Speedemon636
May 8, 2010 06:27 PM
njens118
May 4, 2010 03:44 PM
nikos
Feb 25, 2009 02:05 AM
ozrider
Feb 7, 2006 02:02 PM
radio one
Nov 8, 2005 11:38 PM
