88 cbr tune up help.
Old May 4, 2012 | 01:05 PM
YOUGOTHEBREAk's Avatar
Default 88 cbr tune up help.
What's up guys, I'm pretty new to this scene so bare with me lol. Anyway I need help in knowing what to buy for a good tune up for my 1988 HONDA CBR 600rr.
So if anyone can please give me a list and OR whats the best place (good prices of course ) to buy them. Im really leaning on help for what kind of spark plugs to get, & do they come with wires or coils (correct me if I'm not making sense ) And another thing im focused on is what kind of oil should I put in it (Ill ask the previous owner what he used but you know how that goes sometimes)
P.s I don't plan on working on my bike myself just yet , lol if your wondering.
Thanks.
Old May 4, 2012 | 01:26 PM
74demon's Avatar
for spark plugs i like NGK. Denso are good too. they dont come with wires.
air filter: i use a k&n. there has been some debate whether it's worth it. stock flows great as well.
oil: another very debated topic. i use rotella t6 syntetic. i get it at walmart for like $22/gal. use whatever you like, just make sure its formulated for wet clutches (JASO-MA), not the "energy conserving" car oils. take a few hours and read through some of the oil threads.....
coolant: i use engine ice. again, the topic of many debates. regular, non silicate, coolant works good too.
the biggest part of a "tune up" for your ride is carb cleaning and adjustment. if you dont have the sync and a good understanding of carb stuff, probably would be good to take it to someone with some experience. same with adjusting the valves. feel free to look through the write ups and see if its something you want to tackle.
lube and adjust your chain often.
replace the brake fluid once a year or so.
check your tire pressure more than often, your life depends on it.
Old May 5, 2012 | 01:42 PM
That was perfect thanks man.. what's a good tire pressure for bikes ?
Old May 5, 2012 | 01:55 PM
74demon's Avatar
Most put it somewhere between 38-42, I believe. It should be in your manual or on a sticker on the bike, if it hasnt been removed.
Old May 5, 2012 | 08:40 PM
Got you.
Old May 6, 2012 | 12:28 PM
TahoeRider's Avatar
I also use the OE NGK plugs on mine. Wires & coils should be ok to reuse unless you're having a misfiring issue or something.
I've been using Castrol 4T dino oil, but like 74demon said before as long as it meets the jaso-ma spec you're fine. All these fancy new motorcycle oils didn't really exist back when this bike was made anyway..
Engine Ice is good coolant. I use Honda from the car dealer w/ water wetter mainly because I always have some on my shelf at home anyway.
I 2nd the comment about carb cleaning and carb sync. That will likely make the biggest difference in the bike running well. Out of sync or dirty carbs run like crap.
I usually run approx 38-40 PSI for tire pressure..
Another good idea would be to pick up or download the service manual for the bike. All the tune up and maintenance stuff is laid out in there with detailed instructions. It's a big help when working on the bike, I use mine all the time.
Old May 7, 2012 | 11:04 AM
Thanks bro, that was really helpful as well. Im going to try and find that manual online too.
Old May 7, 2012 | 07:38 PM
TahoeRider's Avatar
here you go..
Motorcycle Honda CBR600F1 Repair Manual Download
Old May 8, 2012 | 05:23 PM
Great! thanks
Congee
May 29, 2014 11:37 PM
stretch_the_apex
Jan 30, 2011 11:58 AM
F4ISmurf
Jun 1, 2010 11:41 AM
red99f4
Mar 4, 2010 10:32 PM
JMart
Jun 29, 2007 08:20 AM
