1987 Hurricane to 2003 CBR600RR Conversion
Old Apr 12, 2014 | 09:10 PM
  #181
dennisgb's Avatar
I'm still quite confused as to what your having a problem with. The bulbs and sockets should be part of your RR headlight assembly. I bought mine used and it came with them. If you have the RR sockets then the RR plugs should plug into them. The harness needs to be cut. The wires should be spliced into the Hurricane harness. I think I suggested you get wiring diagrams for both bikes so you can match the color codes for the wires. The only wires you need from the RR harness are the lights...the rest of the wires are not needed.
Old Apr 13, 2014 | 04:07 PM
  #182
reaper101's Avatar
Ok let me try and reword the situation, I bought my headlamp assesmbly with no bulbs or wires so than I looked for a headlight harness which is the pics I'm showing and than I went to a shop while waiting for the wire to come in I bought the two bulbs now when the wire came in I figured let me try and put the bulbs on the wires yet to my realization they did not fit at all in any of the plugs. On the original plug there's the headlight bulb and the 3 prongs and there's a socket that goes on there to power it< that's where my issue is with the harness and the bulbs my bulbs don't fit in? So either I'm missing sometnin or I got the wrong bulbs or wires, the wire harness in the pics and the two bulbs is all I got am I missing somethin?
Old Apr 14, 2014 | 07:00 AM
  #183
dennisgb's Avatar
Post a picture of the back of the headlight assembly.
Old Apr 30, 2014 | 12:07 AM
  #184
Doc B.'s Avatar
Hi Dennis, just want to say thanks for this great thread. I picked up a '90 CBR in rough but running shape last summer and after an abortive attempt to get original plastic from a flaky ebayer I decided to take the RR conversion approach. So far the setup is a stock 90 CBR with 03RR fairings and seat. A few more bits are being added as I figure out what I want to do - 929 front master cylinder, an aftermarket digital speedo/tach, updated mirrors and turn signals, all that stuff that doubles your initial cost estimate.
As you know keeping up the pace on this kind of project is tricky. I did manage to fit the fairings last fall before my garage got too cold to work
A Danmoto exhaust for a CBRF4 was fitted along with a like new old stock header during the winter.
Anyway, great job, and thanks so much for your inspiration.
Old Apr 30, 2014 | 05:15 AM
  #185
PSonic's Avatar
As you know keeping up the pace on this kind of project is tricky. I did manage to fit the fairings last fall before my garage got too cold to work in.
We can't see your pictures.
Old Apr 30, 2014 | 06:06 AM
  #186
dennisgb's Avatar
I'm glad you found the thread useful...but I want to see the pics!
Old Apr 30, 2014 | 09:40 AM
  #187
Doc B.'s Avatar
Duoh! Sorry guys, my image hosting attempt obviously didn't work. Ipads are pretty limited for this kind of stuff so I will get the image links corrected when I get to my workstation at the office. In the meantime, if the mods would be so kind as to grant me permission to edit my posts I will fix the bad links rather than bulking up the thread with another post. If editing permission is post count based just let me know how many times I need to post "good idea, I agree!"
Old Apr 30, 2014 | 11:04 AM
  #188
Mattson's Avatar
It`s not, and that is exactly the reason why. Only an Admin can grant full pass so I`m of no help there...
Old Apr 30, 2014 | 12:23 PM
  #189
Doc B.'s Avatar
OK, thanks. I've been admin of my own forums for about 15 years and the only thing I know for sure is every forum is set up differently. It's fairly rare to come across a forum that does not allow one to edit their own post. Hopefully the preview function is giving me the true story on my revision of the image links and you can see the images this time. Looks like I also have editing permission now, thank you admin.
The bike is pretty much in the rough in that first pic, with the fairings fitted. Lots of aluminum bending and drilling underneath the plastic, and lots of trimming with a Dremel sanding drum -
Second shot of the DanMoto F4 exhaust uses a 929 passenger peg bracket. That combo bolts right up with no modification. The seat fairing has a test coat of Plasti Dip on it. The first time I threw my leg over the seat I found out how fragile it is, so the finish plan has been revised to vinyl wrap.
By the way Dennis your idea of using the F2 rear hugger trimmed down is great. I will be appropriating your good idea.
Old May 3, 2014 | 10:07 PM
  #190
dennisgb's Avatar
Doc,
Still can't see the pics.
The F2 hugger mod takes a bit of mods to the swing arm. There are brackets that I made and one of the original ones is cut off. It's does look good though. When you get to that point I can post more detailed pictures of the mod.
