CBR 1100XX "Super Blackbird" 1998 - 2003 CBR 1000XX
Misfire 1998 carb model
Old Jun 23, 2010 | 12:10 PM
Dadarob's Avatar
Default Misfire 1998 carb model
Hi my brother heas a 1998 Blackbird CARBURETER model.
It has developed a slight missfire from idle but more noticable between 3000-5000rpm, replaced the plugs with Iridium plugs, checked caps & leads OK, checked coils OK.
Are there any known problems to check (cheap ones would be nice)
The bike rides ok but has bar vibration between 3-5rpm = 60-80mph.
Old Jun 28, 2010 | 02:37 PM
Dean0's Avatar
The only other issue I can think of is the fuel tap diaphragm - if it has split slightly it will cause cylinder 2 to run rich and missfire.
Has gas milage gone crap lately ?
Old Jul 1, 2010 | 01:18 PM
martin121165's Avatar
Hi this is dadarob's brother. got logged on now. tried clamping off vac pipe to fuel tap, no difference. Fuel ecconomy still good. The plugs that i took out were all fine. The colouring of all four were all equal. can't think of anything esle except maybe comprestion down on number four, as when ran from semi cold, number four down pipe is half as hot as the rest. Iv'e got a six month warranty on the bike so i think i will have to take it back the the shop. Not too hopeful about them finding the fault, they fobbed me off about the chain ( it was clunking quite badly) saying that it just needed running for a while, even after a couple of hundred miles. Too dangerous, so i change the chain and sprockets at my own expence.
Old Jul 10, 2010 | 02:32 PM
Default misfire
Thanks for your reply. Funny you should mention carb mixture screw set at 3 1/2 turns. one time i removed the carbs to blow them out at work. 1&2 were at about 2 1/2, and 3&4 were about 3 1/2. when i get a chance i will take carbs off again, and remove the rubbers for further inspection. I might even wrap a bit of insulating tape round them, just to see if there is any change. Bike is out of mot at the moment, so riding it will have to wait a while. i can more or less re-create the misfire staticaly anyway.
Old Jul 11, 2010 | 06:54 AM
Dean0's Avatar
Have a chat with John from JAWS - he is the guru on blackbirds
bicklebok
May 11, 2023 05:45 AM
Shadow
How To's
Sep 12, 2009 02:50 PM
bronson
Aug 10, 2009 08:15 PM
SmokinJoe
Aug 21, 2008 08:25 AM
