Misfire 1998 carb model
Hi my brother heas a 1998 Blackbird CARBURETER model.
It has developed a slight missfire from idle but more noticable between 3000-5000rpm, replaced the plugs with Iridium plugs, checked caps & leads OK, checked coils OK.
Are there any known problems to check (cheap ones would be nice)
The bike rides ok but has bar vibration between 3-5rpm = 60-80mph.
Has gas milage gone crap lately ?
Hi this is dadarob's brother. got logged on now. tried clamping off vac pipe to fuel tap, no difference. Fuel ecconomy still good. The plugs that i took out were all fine. The colouring of all four were all equal. can't think of anything esle except maybe comprestion down on number four, as when ran from semi cold, number four down pipe is half as hot as the rest. Iv'e got a six month warranty on the bike so i think i will have to take it back the the shop. Not too hopeful about them finding the fault, they fobbed me off about the chain ( it was clunking quite badly) saying that it just needed running for a while, even after a couple of hundred miles. Too dangerous, so i change the chain and sprockets at my own expence.
Guest
Posts: n/a
Carb misfire or maybe???
Things that are consistant are usually mechanical. Things that are intermittant are usually electrical. So, with that said, here is what you might look at. If the bike goes "pop, pop --- pop, pop, pop --- pop", you most likely have a fuel problem. So, ride the bike and when it is "popping", slightly put some choke to the bike while holding the throttle in the popping area. If that straightens out the popping, you have a fuel problem. You will also notice a smoothing out of your low speed surging (some feel it is a "touchy throttle linkage"). You have a vacuum leak and or a low speed jet plugged. The vacuum leak that I would suspect is between the carbs and the engine (the rubber boots). Are they cracked? In otherwords, it is running lean. I have also seen bikes that act the same way when the owner turns the slow speed idle mixture screw out 3.5 or more turns.
If adding a little choke does nothing, then it is probably in you emission control system (if so equipped).
misfire
Thanks for your reply. Funny you should mention carb mixture screw set at 3 1/2 turns. one time i removed the carbs to blow them out at work. 1&2 were at about 2 1/2, and 3&4 were about 3 1/2. when i get a chance i will take carbs off again, and remove the rubbers for further inspection. I might even wrap a bit of insulating tape round them, just to see if there is any change. Bike is out of mot at the moment, so riding it will have to wait a while. i can more or less re-create the misfire staticaly anyway.
Have a chat with John from JAWS - he is the guru on blackbirds
Guest
Posts: n/a
Carb adjustment
Set the mixture screws at about 2 to 2.5 out (depending on elevation where you live. Higher the elevation the less turns out). Also, if you are taking the carbs off, check those small low speed jets. They are real small (hard to see through at Classic's age!). Heck, I think I used a piece of 12 ga. stranded copper electrical wire (THHN) unwound it and used one strand to push through a piece of crud when my low speed jet was clogged. That is how small those holes are. My bike back popped and when I cleared that small piece of crud, it cleared right up and stopped the popping. Now after letting it sit unused for about 8 months, I have small pop again and need to use a little bit of choke to stop the popping. Looks like I will be joining you on a carb tear down, but I will put some "sea foam" (auto stores have it, it is a cleaner additive) in it, run it and see if I can get it to clear up.
