FAQ'S(Frequently Asked Questions)1100xx
Hey guys figure I would make a list so this would help everyone out with questions that come along. If you have anything good or want to add let me know and ill add it to the list. I left blanks since I myself have no clue.
Here are the most common questions asked about the 1100xx:
Are these bikes fuel injected:
Yes
Grade Gas:
What are the most common power mod's to do:
1.Power Commander
2.-1 Front Sprocket, +2 Rear Sprocket
3.Slip On(aftermarket exhaust)
4.Air Filter
What are the most common body mod's to do:
1.Undertail kit
2.Hid's
3.Good frame sliders(One's that require no cuts haven't had significant luck with working)
4.Tires(Find a good brand name that's proven to work)
5.Aftermarket Windscreens
6.Flush mounts(Blinker lights)
7.Good Chains
What are some good websites to get parts for it:
Oem:
www.bikebandit.com
Aftermarket:
My valves tick is this normal?:
Yes this is. In order for your valves to work properly you need to have clearance. With having clearance you get a "ticking noise" which is normal. If you don't have any clearance they will be to tight you will have major major problems.
Size of front and back tires stock:
Yes
Grade Gas:
1.Power Commander
4.Air Filter
1.Undertail kit
2.Hid's
7.Good Chains
Oem:
www.bikebandit.com
Aftermarket:
99 and later are FI. 97 and 98 are carb versions.
Here's something that you might find interesting
http://en.wikipedia.org/wiki/Honda_CBR1100XX
For CBR1100xx parts you can try Jaws in the UK.
