FAQ'S(Frequently Asked Questions) 954
Hey guys figure I would make a list so this would help everyone out with questions that come along. If you have anything good or want to add let me know and ill add it to the list. I left blanks since I myself have no clue.
Here are the most common questions asked about the 954:
Are these bikes fuel injected:
Yes
Grade Gas:
91 (ron) 87 US octane or better
What are the most common power mod's to do:
1.Power Commander
2.-1 Front Sprocket, +2 Rear Sprocket
3.Slip On(aftermarket exhaust)
4.Air Filter
What are the most common body mod's to do:
1.Undertail kit
2.Hid's
3.Good frame sliders(One's that require no cuts haven't had significant luck with working)
4.Tires(Find a good brand name that's proven to work)
5.Aftermarket Windscreens
6.Flush mounts(Blinker lights)
7.Good Chains
What are some good websites to get parts for it:
Oem:
www.bikebandit.com
Aftermarket:
eBay, bikebandit.com has aftermarket section
Manuals:
https://cbrforum.com/forum/cbr-954rr-21/cbr-954-service-manual-23443/
My valves tick is this normal?:
Yes this is. In order for your valves to work properly you need to have clearance. With having clearance you get a "ticking noise" which is normal. If you don't have any clearance they will be to tight you will have major major problems.
Oil:
10w-40 Motorcycle Oil
Oil Filters:
AC Delco PF1237
NAPA Gold 1365
Purolator L14612
STP S-02876
WalMart SuperTech ST6607
WIX 51365
Oil: SAE 10W-40, 3.9 qt (with new filter)
Tires: pressure 36 & 42
Chain: 530 - 108
Main fuse: 30 A
Valve clearance check: every 15,000 miles
Size of front and back tires stock:
120/70/17(Front)
190/50/17(Back)
Yes
Grade Gas:
1.Power Commander
4.Air Filter
1.Undertail kit
2.Hid's
7.Good Chains
Oem:
www.bikebandit.com
Aftermarket:
Manuals:
Oil:
Oil Filters:
AC Delco PF1237
NAPA Gold 1365
Purolator L14612
STP S-02876
WIX 51365
Chain: 530 - 108
Main fuse: 30 A
120/70/17(Front)
190/50/17(Back)
Yes
Grade Gas:
1.Power Commander
4.Air Filter
1.Undertail kit
2.Hid's
3.Good frame sliders easy to install and will save your fairings. Don't get cheap ones. They will break!
4.Tires(Find a good brand name that's proven to work) ei michelin, dunlap, ect.
7.Chain and Sprockets (never replace one with out the other)
Oem:
www.bikebandit.com
Aftermarket:
Manuals:
https://cbrforum.com/forum/showthread.php?t=23443
Don't know too much about clearance causing ticks, however the cct will tick. It happens and is ok.
120/70/17
190/50/17
Yes
Grade Gas:
1.Power Commander
4.Air Filter
1.Undertail kit
2.Hid's
Oem:
www.bikebandit.com
Aftermarket:
Manuals:
120/70/17
190/50/17
Added to it.
Oil Filters:
AC Delco PF1237
NAPA Gold 1365
Purolator L14612
STP S-02876
WIX 51365
Chain: 530 - 108
Main fuse: 30 A
AC Delco PF1237
NAPA Gold 1365
Purolator L14612
STP S-02876
WIX 51365
Chain: 530 - 108
Main fuse: 30 A
Wouldn't the gas have to be 91+? I don't have a manual, but even my 96 ZX-6E required premium.
What about E10? I've been looking all over for some 100% pure dinosaur juice, but big corn is cornholing us at every gas station with this E10 bull****. The stations I know of that sale 100% are too far away to go fill up on the bike, and I know my wife's 92x gets better mileage with the real deal instead of E10, so what about the bike?
