Stupid question. Please Help
hey guys, my 06 1000rr seems like the battery is dead....if i put it on a trickle charger for the night, will the battery hold the charge for a couple days? next question is....how do i get to the battery on it...my wife threw away the manual so i dont have any references...your help is appreciated..thanks
Guest
Posts: n/a
If your battery has not totally died it will hold the trick charge mate..
The only way you will find out is to charge her and see if the battery holds it ..
To find out how to get to it ..go download a manual for her below..
To remove the seat and get access to the battery you need to locate the two allen head screws that arebetween the seat's foam padding andits nylon base. Just gently lift up on the corners (at the rear of the seat) and you'll see them.
Guest
Posts: n/a
ORIGINAL: NC CBR1K
It wont let me download the manual from there. Im sure the battery is under the seat. Can anyone just tell me what parts i need to take off to be able to get to it.. Thanks
The manuals are pretty big and take quite a while to load ..
patients is a virtue
