Question for 08 CBR owners.
Old Nov 4, 2008 | 09:24 PM
dirtyabes's Avatar
Default Question for 08 CBR owners.
well i have an 08 CBR and just wanted to ask if when you guys start your bikes in nuetral and shift into 1st, do you guys have a moderate kick into first? by moderate kick i mean the bike jolts a bit but does not jump forward. other than that it shifts great im just concerned about the initial shift into 1st gear from nuetral.
Old Nov 4, 2008 | 10:02 PM
ta8218's Avatar
Default RE: Question for 08 CBR owners.
They all have a pretty good clunk into first, but as long as the bike doesn't want to go afterwards, you're fine. If it were to pull while the clutch lever was all the way back then you would have clutch issues, but it doesn't seem the case.
Old Nov 5, 2008 | 02:23 AM
FINGERZ's Avatar
Let the bike warm up!! I have to let my warm up and the idle goes to normal levels. Oh and its an 08'
Old Nov 5, 2008 | 04:51 AM
TheX's Avatar
I have the same kick in my '08, nothing to worry about.
Old Nov 6, 2008 | 04:05 PM
dirtyabes's Avatar
right on thanx for the replies.
Old Nov 7, 2008 | 05:25 PM
TBagr's Avatar
let it warm up and the lower the RPMs the less the clunk will be.
Old Nov 8, 2008 | 10:21 PM
greenet's Avatar
Yep.Mine does it too.Its normal
Old Jan 12, 2009 | 05:43 PM
2008CBR1000's Avatar
Mines the same, no worries.
Old Jan 15, 2009 | 03:37 PM
Will1000RR's Avatar
i usually allow the engine to warm up above 99 degrees...no problems....
Old Jan 15, 2009 | 10:48 PM
SD2007's Avatar
My '07 has the same problem,sometimes there'sa nastykick when I engage 1st gear. I've noticed that if I give the engine a couple quick revs (to 4000 RPM or so) before notching the shifter down, the kick is greatly reduced. I'm not sure if this will work for the '08, but it seems to help on my bike.
jloshotz
Dec 24, 2009 11:31 PM
MIKE1218
Apr 5, 2009 11:40 AM
PlayfulGod
Jun 23, 2008 09:31 PM
NINE2NINE
Nov 22, 2006 07:02 PM
milletary
Jan 26, 2006 11:03 AM
