powerband problems
Old Apr 14, 2006 | 12:30 AM
cbrrookie's Avatar
Default powerband problems
Hey guys
every time im in second gear i have a hard time getting the bike up
does anyone know precisely at what RPM's does the bike powerband starts?
I thought it was around 6K but every time I lift it i have to keep using the clutch?
I know the bike has power?
thanks
Old Apr 16, 2006 | 08:45 PM
newb's Avatar
Default RE: powerband problems
I'm not sure how to answer? I'm new to my 1K and the hole rpm range seems like a power band! If your having a hard time getting the front up in second then you should check the bike over. It should be up if your on it 5000k or so.
Old Apr 27, 2006 | 09:54 PM
hobbs51's Avatar
ha cbrrookie,
my god when mine seen 600 miles i said it is time man i layed on the gas tank in first it was like i wasnt enen their shifted to 2nd stoill laying on the tank and it came up at me again i believe i would check the throtle cable bacause this bike has power in weigh 195 and it has no problem
Old Apr 27, 2006 | 10:11 PM
cbrrookie's Avatar
turns out it wasn't tuned right
i really need to buy a dyno .
Old May 2, 2006 | 11:30 PM
sidthafish's Avatar
I'm just curious how you found out it wasn't tuned right; I seem to be having the same issue. I can take it to 10k RPM in first and I'm glued to the ground. My partner bought one exactly the same and has no problem getting it off the ground but there is a 40lb weight difference between us. I know the power is there but I just can't seem to get it up without dumping the clutch.
m21oliver
Oct 1, 2018 10:52 AM
flexxluther
Mar 12, 2008 09:26 AM
Paulie
Sep 17, 2007 05:33 PM
silvr002001
Nov 26, 2006 11:32 AM
cbrhomie600
Feb 26, 2006 01:02 AM
