MAINTANENCE
Old May 22, 2007 | 07:35 PM
r1b11963's Avatar
Default MAINTANENCE
I will be changing the oil and filter very soon.In the owners manual it indicates to change the Sealing Washer when the oil filter is getting changed.
Does the sealing washer come with the new oil filter or do i have to buy it seperatly.Also i could'nt find anything about the air filter in the owners manual.
My bike has 4k on it and how often doesthe air filter have to be cleand or replaced.Thanks
Old May 23, 2007 | 04:26 PM
scottnh1970's Avatar
Default RE: MAINTANENCE
The manual for my 06 states to replace if the seal washer looks worn or if broken. If not, just clean and put back. Check to see if you have any oil leaks from the drain plug. If there is, then replace. And no, the oil filter does not come with one.
If you have an aftermarket filter, then I'd clean it ever other oil change. If your have a stock one follow the manual on replacement. Also depends when you change your oil. Some on the forum change every 1500. Others longer. Go by the manual.
Old May 23, 2007 | 11:50 PM
CBR1000's Avatar
I change the crush washer every time. They are cheap. Buy four or five when you pick up the oil and filter.
Old May 24, 2007 | 08:29 PM
r1b11963's Avatar
Thanks for the heads up and i will follow the Manual's instructions.
cybaster
Aug 15, 2010 08:09 PM
fieky21
Sep 21, 2008 01:28 PM
CBenRieder600
Aug 26, 2007 08:14 PM
MofoSachem
Aug 30, 2005 06:11 PM
