How-to adjust clutch?
I tried searching for awhile with no success.
I'm a super-n00b so bear with me. I own a 2004 CBR1000rr and after getting into an accident I had to replace the clutch lever. Now the clutch appears to disengage with less than a touch of the lever. This can't be good for the clutch so I'd assume the clutch needs to be adjusted. After searching it appears that there are two places to adjust it but I haven't found any pictures to help me locate these places. Any help is greatly appreciated!
The only thing you can do with a hydraulic clutch is adjust the lever itself. Push the lever forward, only lightly as far as it goes, then turn the wheel adjuster on top of the clutch lever - it has numbers on it. This changes how far in or out the lever engages the clutch. You can't actually adjust the clutch itself though.
