hesd
Old Oct 15, 2008 | 03:07 AM
sacbr1000rr's Avatar
Default hesd
how different is the dampeneron the 07 gsxr to the hesd system. when i try to u-turn my 1000rr feels like it wants to jacknife, as opposed to my bro's gsxr and a friends 07 1000rr. a u-turn on their bikes is smooth. is my hesd out, need an upgrade, or am i a retard?
Old Oct 15, 2008 | 11:03 AM
RojerLockless's Avatar
Default RE: hesd
you have an 08 1000RR?
my dampener works as intended as in.. I keep forgetting its even on there, it never makes me turn slower and activates based on my speed so i'm 100% happy with mine. if it's not doing that take it back to the shop.
Old Oct 15, 2008 | 07:05 PM
toptaz1000rr's Avatar
Default RE: hesd
HSED system for teh street and 80% of the track is a great system ... much better then the gsxr set up
if it is 'bad' the fi light will tell you
Old Oct 15, 2008 | 07:25 PM
TheX's Avatar
Default RE: hesd
I can't tell it's there at low speeds. So far it's meeting all of my expectations.
Old Oct 15, 2008 | 09:34 PM
VP's Avatar
VP
Default RE: hesd
It'the amount of dampening is determined by the speed you are riding at... low speeds the dampener is probably completely turned off
to me it sounds like you need air in your tires
Old Oct 15, 2008 | 11:30 PM
Default RE: hesd
ill have to check the air pressure then, that does sound about right.
Old Oct 16, 2008 | 04:16 PM
TBagr's Avatar
Default RE: hesd
the HESD on my 06 and 08 work flawless. as mentioned above i believe your problem is something else.
Old Oct 16, 2008 | 05:08 PM
VP's Avatar
VP
Default RE: hesd
ORIGINAL: sacbr1000rr
Remember to check the tires pressure while they are still cold... then remember how much air you need to put in each end. Check the VIN plate or owners manual for your model. inflating them after riding gives you an inaccurate gauge of the actual amount of air in the tires.
Old Oct 16, 2008 | 06:48 PM
Default RE: hesd
heh yeah I got a flat on my front tire on my 08 and I thought the dampener flipped out and turned on full I was pissed! then I noticed I had a flat and was a whole other kind of pissed!
cbrtripleblack
Jun 16, 2009 07:48 AM
egdcbr600rr
Mar 8, 2009 10:18 PM
firefighter110a
Mar 15, 2008 11:22 PM
birde
Oct 30, 2007 06:56 PM
1wild929
Feb 15, 2006 11:38 PM
