hesd problem
Old Oct 30, 2007 | 05:21 PM
birde's Avatar
Default hesd problem
alright i dont know if this is just me or was a fault in my damper... was going around a bend i usually take easy and it felt like my bike didnt want to turn and it was all stiff and i almost drilled a car ... has this happened to anyone and / or is this a fault in my damper or just me?
Old Oct 30, 2007 | 06:56 PM
baxsom's Avatar
Default RE: hesd problem
test your HESD
Raise and support the front of the bike. Move the steering back and forth several times to get a "feel" for minimum damping.
1. Lower the side stand
2. Shift tranny into a gear other than neutral.
3. Open the throttle fully ( WFO ).
4. Turn the ignition switch on ( don't start the engine ) while maintaining steps 1-3.
The HESD icon on the LCD display should start blinking ( If not, start over ).
For the next 10 seconds, the ECM will set the HESD to maximum damping ( full-stiff ). Compare this to minimum damping. If there is no change, replace the HESD unit.
NOTE: This test will not work if the Malfunction Indicator Lamp has indicated a problem exists in the PGM-DSFI ( MIL is flashing ).
sacbr1000rr
Oct 16, 2008 06:48 PM
firefighter110a
Mar 15, 2008 11:22 PM
dwhite645
Jul 15, 2007 10:37 PM
Evan_CBR
Jul 20, 2006 01:45 AM
1wild929
Feb 15, 2006 11:38 PM
