Damage control
Old Dec 24, 2009 | 02:29 PM
Whitedog's Avatar
Question Damage control
Hey guys, I crashed my 05 Repsol this summer and am starting to repair it. The plastic is trash, as is the sub-frame. Frame and suspension are intact and the motor is fine except what Honda calls a water joint on the left side. It is broken, the 2 mounting bolts all that retains it. 1 is very accessable, the other is right behind the frame. My plan is to remove the exhaust and the mounting bolts and let the motor rotate down, hinging at the swing arm pivot. Any Advice?
Old Dec 25, 2009 | 01:31 PM
lil_schmitty01's Avatar
Remove the radiator and headers first, it will allow the motor to rotate further w/o damaging the radiator. Make sure you keep track of where the spacers go, they are different sizes.
PM Sent.
Old Dec 27, 2009 | 04:51 PM
Whitedog's Avatar
Red face Damage Control cont...
Thanks for the advise on the engine pivot delima. Anybody got a good line on aftermarket plastic? I've been looking at Auctmarts and the other Ebay stuff, but I don't know any one that has actually used any.
Old Jan 22, 2010 | 04:21 PM
burk3385's Avatar
April 2012 Ride of the Month
I havent personally used the Hong Kong auctmart plastices but I know 2 people who have. They do not always fit perfectly but if you take your time you can get them to fit pretty well. They look great once installed tho. There is also a ton of different styles to choose from.
Old Feb 16, 2010 | 03:59 PM
shodog's Avatar
I have a set of the HK fairings from an ebay seller named stylechoose. The fit was fine but I've melted the lower near the exhaust manifold. The Inferior plastic just couldn't hold up to the heat. With that said, I'd still buy another set.
Old Feb 18, 2010 | 12:54 PM
dawoonj's Avatar
I heard good and bad .... some fit great .. .some fit like sh#@$ ....sometimes the paint matches (if not buying a full set).... sometime it don't .... as for the melting, use heat tape!! They're really hit or miss!!
Old Feb 27, 2010 | 07:14 PM
toobyfore's Avatar
do you think you could send me a pic of your farings from stylechoose? samfoltz@gmail.com - I just bought a set and I have a hole where the lower front engine bolt is, and was wondering if your was the same way, Thanks
dyracuse
Jan 18, 2010 07:58 PM
Etalono61
Oct 1, 2008 10:47 PM
cnestea
Nov 3, 2007 03:52 PM
peterk
Jan 21, 2007 06:29 PM
javscbr
Feb 20, 2006 02:59 PM
