possible damage???
Old Jan 20, 2007 | 11:39 PM
peterk's Avatar
Default possible damage???
To cut a long story short, thanks to Wazza 57 (thanks again Waz) i can make an offer on an 87 cbr which i would like for motor/spares. Problem is it hasn't been started for 2 yrs and when the dude tried to jump it from a commodore (Aust car) probably 3.8 litre he thinks he has done some damage, possible starter or solarnoid, is this likely? Has been unable to start the bike since he did this. He thinks too much power went thru battery, etc??? I haven't seen bike as yet, trying to get some ideas first, i thought maybe lots of power has welded the solarnoid points together?? Any ideas will be helpful before i decide if i want to make an offer. thanks pete...
Old Jan 21, 2007 | 04:28 AM
MarkR's Avatar
Default RE: possible damage???
I don't think it should damage it, because the voltage should be in spec and that what counts. I would, of course, not have the car running.
If he didn’t use protected jumper leads, then things can go wrong
Old Jan 21, 2007 | 06:14 AM
waz57's Avatar
Hi Pete, hey I know it sounds simple but have a look at the fuses, when I was speakign to Peter he sounded like he wouldnt have checked them there is also another set of carbs as he said he had replaced them last year. Also if you do buy it I am after two items for my old girl thats if you wanted to sell them of course its the dask souround and the cover that goes up under the headlight and between the front gaurd
Wazza
Old Jan 21, 2007 | 09:40 AM
Trips's Avatar
It could just be the battery. I had a dead flat battery and even though it was jump started from a car it wouldn't start. The battery had to have more charge in it.
Old Jan 21, 2007 | 06:29 PM
Chuck Norris's Avatar
Both electrical systems are 12-volt. There should be no problem with jumpstarting. Unless he got the positvite, and negetive cables on the wrong post. I agree with waz57. I'd check the fuses. If something went wrong. It should of blown a fuse before damaging anything else. Jump starting alone wil not hurt the bike. My battery is junk. If I jump start from a car. The car has to be running. The bike will turn over fast. But Won't start until the car is running. I've never had a problem with anything else. Good luck.
dyracuse
Jan 18, 2010 07:58 PM
Etalono61
Oct 1, 2008 10:47 PM
cnestea
Nov 3, 2007 03:52 PM
javscbr
Feb 20, 2006 02:59 PM
Bikerboy202066
Jul 7, 2005 07:10 PM
