06 1000rr garage rebuild
Well I started with an auction CBR1000rr with an estimated 8xxx miles on it.
The good news is it had a few aftermarket parts. Exhaust (Akrapovic), carbon fiber front/rear fenders, steering dampener and a few others. I begain collecting parts I knew I would need, and also ordered some Auctmarts plastic..
When I got the bike home I found the engine was some how damaged during the crash, further inspection found the pistons in cylinders three and four had hit and bent the intake valves.
Anyways, I got the new head on and shimmed. The bike started up and sounded good at an idle, but had a VERY bad rod knock.. :'(
So, out comes the engine. I pulled it last night and wasn't sure how bad the damage was going to be.
Found number three rod had spun but all others looked good. Block looks good and cylinders look O.K.
Now it looks like I'll be selling the 05 to fund the 06 TOTAL rebuild. The only good that will come from this other than a engine with new bearings is, I might go with some aftermarket pistons and cams while I'm there.
