Battery tenders?
Old Jan 8, 2008 | 06:42 AM
sweetdeal's Avatar
Default Battery tenders?
I havea battery tender, worked great last winter for storage, i removed the battery and brought it inside and hooked it up all winter, No problems, My question is could you use a single tender in series to 2 separate batteries.
I am thinking as long as both batteries are charged and newerthe battery tender can just send it's "trickle" then it wouldn't cause much ofa problem? I only see a problem if one of the batteries is older and doesn't hold the charge and would cause the tender to go into charge mode more often than it should? opinions?
Old Jan 8, 2008 | 07:02 AM
SD2007's Avatar
Default RE: Battery tenders?
You could but the batteries must be connected in parallel,be the samevoltage (#ofcells), same type (cell chemistry)and be more or less fully charged. Capacities don't need to be the same. I've got a 26AH and a 4AH that have been sharing the same charger for 3 years. They just sit there happy as clams at 13.2 volts day after day.
Old Jan 8, 2008 | 08:31 AM
telgren's Avatar
ideally yeah you can, but its not reccomended. Just spend the $30 for another charger.
Old Jan 8, 2008 | 09:13 AM
sweetdeal's Avatar
Fak dat,
He can get his own charger, i was just curious if it was something people have tried, if his goes dead he can have it then lol.
Old Jan 8, 2008 | 09:42 AM
richhowerton's Avatar
I would not do it, It is not worth the chance that you could have a prob so just pick up another one they are cheep.
Old Jan 8, 2008 | 09:50 AM
CBR1000rider's Avatar
ORIGINAL: sweetdeal
You can buy a Battery Tender thathastwo negative and two positive cables for charging two batteries at the same time. Very inexpensive and worth checking out.
Old Jan 8, 2008 | 10:03 AM
I did not know they had that. Sweet Ihave the tender hooked to my battery all the time with the screw down and I just plug the bike in when instorage.
Old Jan 8, 2008 | 12:36 PM
Here is a link to Battery Tender's website. The cost is $119.99.
http://batterytender.com/product_inf...fbcd0d8b587e61
Old Jan 8, 2008 | 04:49 PM
mininsx's Avatar
I've got 2 bikes and one Battery Tender. I just leave it on one for a while then switch to the other one.
Old Jan 8, 2008 | 05:41 PM
Good point! You can do that too.
estate4life
Dec 4, 2012 11:08 PM
itsgroll
Nov 9, 2010 08:48 AM
jharbinson
Dec 31, 2009 09:23 AM
njdjh2o
Apr 11, 2008 07:20 PM
MDZ600F4i
Oct 18, 2006 07:50 PM
