04 1000rr
Old Mar 15, 2012 | 09:22 AM
04cbr1000rr's Avatar
Default 04 1000rr
Hey guys, about to do a compression test on my 04 cbr1000rr. Just want to know if anyone knows what the psi in each cylinder is supposed to be. Thanks for the help.
Old Mar 15, 2012 | 11:14 AM
Shadow's Avatar
Try Stephy G's CBR F4i Page and download the manual
Old Mar 15, 2012 | 11:27 AM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
The specs on an '08 1000RR is 174 psi at 210 rpm. I don't know if the '04 is much different. The engine was redesigned in '08.
Old Mar 15, 2012 | 06:52 PM
justasquid's Avatar
It depends on if you test it dry or wet. Dry testing usually nets lower psi readings. Elevation can also affect your reading. the higher your elevation is from sea level, the less psi you'll read on your gauge. Example, a psi reading of 150 at sea level would be around 120 psi at 6,000 feet above sea level. So be careful when taking into consideration psi readings.
The most useful thing about the psi guage is measuring the percentage difference between the cylinders. Generally, they should all fall within 10 percent of each other.
Old Mar 16, 2012 | 08:21 AM
Thanks squid i appreciate the help. Going to do the test tomorrow so crossing my fingers it doesn't need rebuilt cause we just hit an unusual warm streak where I live and Im dying to ride!
FrankTheTank707
Feb 27, 2012 05:15 AM
plasstik
May 14, 2011 09:53 PM
RaceIt454
Jul 22, 2009 12:14 AM
DEADBROKE
Dec 6, 2006 08:13 AM
