Vibrating Front End
Old Jul 24, 2007 | 05:14 AM
morpheous283's Avatar
Default Vibrating Front End
Afternoon all,
Been about a year since I was last on here, kinda dissappeared off the face of the planet for a bit. CBR still going well tho apart from a vibration on the front end. You don't feel it when you are accelerating, only when coasting and it diminished when braking. Think my wheel balance is fecked, or do you think i've got some warped brake disks or shot bearings ??
Any suggestions ideas most welcome.
Kev.
Old Jul 24, 2007 | 06:39 AM
malbojah's Avatar
Default RE: Vibrating Front End
Most likely the front tire is severly cupped. If you run your hand across the tire from the center to the edge it should be nice and smooth. If there is a depression just off center then rising back up towards the edge, it's cupped.
Old Jul 24, 2007 | 09:47 AM
Thanks for the tip, I'll check that tonight when I get home. I'm 99% sure you are right tho as I am needing a new tyre on the front, it's down to its wear markers. I would have been replacing it soon anyway so I guess this might bring d-day forward :-)
Thanks,
Kev.
Old Jul 24, 2007 | 10:10 AM
malbojah's Avatar
Yeah, if the front tire is an older Dunlop they seem to wear unevenly faster.
Old Jul 25, 2007 | 12:30 AM
HeavyCBR's Avatar
I'm having a similar issue....
My front end shakes pretty bad. At highway speed, if I stand up and look over the front, I can see the fender shaking violently and the whole front end shakes back and forth. To me this would seem to be a badly balanced tire. However, I had the tire rebalanced, same problem. Had the tire replaced, same problem. I replaced the bearings less than a year ago aswell so I'd tend to rule that out, but maybe I did a poor job and they're bad again?!? Any other ideas guys?
Old Jul 25, 2007 | 12:58 AM
MarkR's Avatar
could be a buckled wheel or a warp disc
Old Jul 27, 2007 | 11:41 PM
HeavyCBR's Avatar
ORIGINAL: MarkR
So a warped disc could effect the front end even when not on the brakes?
asides
Jul 23, 2011 01:41 PM
slvr05wrx
Aug 23, 2007 05:20 AM
morpheous283
Jul 27, 2007 05:54 AM
ezarj
Jun 19, 2007 04:00 PM
nathankeister
Oct 15, 2006 06:07 PM
