Start button jamming
Old 09-27-2011, 03:45 PM
hmm's Avatar
hmm
hmm is offline
Default Start button jamming
Over the past week my start button has been a bit temperamental. It hasn't been going in far enough to make contact to start so I've been jiggling it around until it did. Now I don't seem to be able to make it work at all.
Have opened the switch assembly up. Can I get in there to have a look? Is it possible to remove the headlamp switch assembly which is above the starter switch?
Can I cut the ignition wires temporarily and hold them together to get her started until I find something more permanent?
Cheers.
Old 09-27-2011, 04:50 PM
CBR1988's Avatar
Senior Member & Lord of the Odometer (300,000 Mles) & Counting
Have opened the switch assembly up. Can I get in there to have a look? YES
Is it possible to remove the headlamp switch assembly which is above the starter switch? YES
Cheers.
Yes, but a cheap Halfords auto store or a marine waterproof switch that is a momentary type for the starter would be a better temp with a rotary dial switch for the ignition, pretty easy to wire that up till you find a new or good replacement.
Dub
Old 09-27-2011, 06:22 PM
hmm's Avatar
hmm
hmm is offline
Thanks Dub,
Just spent a couple of hours trying to get into the switch but without much luck. So I got out my Haynes manual, traced the wires from the switch and spliced in a couple of new wires that I can join whenever I want to start her up. I'll buy a switch tomorrow from Halfords or Maplin.
When I finished it was midnight but I had to get out my cheap telescope to look at the heavens because I could see Jupiter in the sky. In the telescope I could see the markings on the planet and four moons. That's 370 million miles from here - kind of puts things in perspective doesn't it.
Old 09-27-2011, 07:12 PM
CBR1988's Avatar
Hey:
Clear fall skys in the UK is a big event, so I would be doing the same, can't miss that.
Maybe you'll see some of the space junk and if it is getting bigger in the Tscope Duck and run fast, far far away.LOL
Dub
Old 09-27-2011, 08:57 PM
Piranha's Avatar
Did somebody pull the 'super-glue-your-start-button-prank' on you?
Thats a dirty-dirty prank..... dirty
Old 09-28-2011, 06:19 AM
hawkwind's Avatar
I'd just get this, it'll probably work out cheaper in the end
Honda CBR1000 / CBR 1000 F Right Hand Switch | eBay
There are others on e-bay as well, maybe a bit cheaper.
Old 09-28-2011, 06:26 AM
hawkwind's Avatar
Sorry double post.
Old 09-28-2011, 02:52 PM
hmm's Avatar
hmm
hmm is offline
Bought a push button from Maplin, £2-19. Cheaper than a 20-year old switch on eBay.
Having said that, the starter button worked this evening (but not this morning).
brikacid
11-07-2011 11:24 AM
Ghostrider600
09-14-2009 12:05 PM
Ghostrider600
09-12-2009 05:52 PM
abelg
05-27-2009 04:36 AM
mikemcw
04-26-2009 08:00 PM
Quick Reply: Start button jamming
