Silly Question?
Old Jun 26, 2007 | 01:50 PM
esterbenz's Avatar
Default Silly Question?
I know this may be a silly question, but when inspecting a used bike, is there any way to tell if it's been jetted or not, without tearing it apart?
Thanks.
Old Jun 26, 2007 | 02:08 PM
Default RE: Silly Question?
Not a silly question. If you don't know, then you don't know, there's nothing wrong with that. As for being able to tell, I don't see how visually you could tell. The jets are inside the carburetors. Without disassembling them, you wouldn't know for sure.
Old Jun 27, 2007 | 12:20 PM
esterbenz's Avatar
Thanks, that what I suspected. I just thought there might be some performace charastic that might give you a clue. The bike I'm looking at has aftermarket exhaust so I was concerned that it was carburated properly. I guess the only way to know without dissasembling the carbs is to put an EGA on it to make sure there are no A/F issues.
Thanks.
Old Jun 27, 2007 | 01:22 PM
malbojah's Avatar
If the owner will let you lift up the tank, you can remove the diaphram off a carb and see if an aftermarket needle if installed
Old Jun 29, 2007 | 06:40 AM
Latsky's Avatar
Hope you fine the answer you are looking for mate!! But the best thing to do is make sure if you can!!
jimfai
Mar 24, 2009 10:13 AM
fiveoh
Feb 16, 2009 02:57 AM
Karl
Mar 25, 2008 05:58 AM
thegreenbandit
Mar 23, 2008 07:44 PM
j_bezzy85
May 21, 2007 11:44 PM
