Regulator/Rectifier
Old Dec 30, 2008 | 01:03 PM
TMAX's Avatar
Default Regulator/Rectifier
Does anybody know how to test the R/R? I have an 88 1000 Hurricane and the manual doesn't tell how to test mine. Are the R/Rs interchangeable with other years? I think mine might be going bad or I have a wiring problem.
Old Dec 30, 2008 | 04:55 PM
Trips's Avatar
Default RE: Regulator/Rectifier
Put a multimeter on it.
At idle it should be showing around 13.8v
At 5000rpm it should be around 14.5v
If it showing less or not increasing at all when you rev the bike then its cactus.
If the regulator part just blows than it will show around 15v on onwards and will boil your battery dry.
Old Dec 30, 2008 | 08:33 PM
Shadow's Avatar
Try this manual ( your link Trips ? )
Pge 217 has test procedure.
http://myweb.tiscali.co.uk/midlife/i...ice_Manual.pdf
What are the symptoms ? I've done a few of these................[X(]
Old Jan 3, 2009 | 09:13 AM
paul6585's Avatar
Tons of info on this site for the R/R.A search should provide all the info you will need. Here are some links from this site that I keep handy:
https://cbrforum.com/m_337344/mpage_2/key_/tm.htm
https://cbrforum.com/m_461479/tm.htm
http://www.electrosport.com/street/s...reet_46150.php
Good Luck!!
paul_schmd
May 8, 2010 11:09 PM
chrisrc
CBR1000F Wanted / Swap
Apr 19, 2010 03:03 AM
cbrsixpack
The Hurricane Saloon
18
Jan 9, 2010 02:18 PM
shrek
Feb 5, 2008 09:58 AM
jeffrimerman
Dec 22, 2006 03:53 AM
