Regulator/Rectifier
Does anybody know how to test the R/R? I have an 88 1000 Hurricane and the manual doesn't tell how to test mine. Are the R/Rs interchangeable with other years? I think mine might be going bad or I have a wiring problem.
RE: Regulator/Rectifier
Put a multimeter on it.
At idle it should be showing around 13.8v At 5000rpm it should be around 14.5v If it showing less or not increasing at all when you rev the bike then its cactus. If the regulator part just blows than it will show around 15v on onwards and will boil your battery dry. |
Try this manual ( your link Trips ? )
Pge 217 has test procedure. http://myweb.tiscali.co.uk/midlife/i...ice_Manual.pdf What are the symptoms ? I've done a few of these................[X(] |
Tons of info on this site for the R/R.A search should provide all the info you will need. Here are some links from this site that I keep handy:
https://cbrforum.com/m_337344/mpage_2/key_/tm.htm https://cbrforum.com/m_337344/mpage_2/key_/tm.htm https://cbrforum.com/m_461479/tm.htm http://www.electrosport.com/street/s...reet_46150.php Good Luck!! |
