regulator rectifier
Old Dec 11, 2006 | 06:32 AM
jeffrimerman's Avatar
Default regulator rectifier
Someone told me that there is only two things to cause my bike to hesitate and cut out for a split second when I turn my turn signals on. That is the regulator rectifier, or the generator. I saw on ebay a regulator that claims to increase power by up to 8%. Is this true? I might as well change one then if that duzn't work try the other since just taking the bike in would cost some bucks. Anyone else have the same problem?
http://cgi.ebay.com/ebaymotors/Honda...spagenameZWDVW
Old Dec 11, 2006 | 08:00 AM
highmilage's Avatar
Default RE: regulator rectifier
Never heard of it, does the same thing happen when you switch on the head light? if not it aint your rec/reg or generator. When mine went south, it was obvious, bike wouldn't run with any light on and puting a voltmeter across the battery terminals showed no power going into the battery.
Old Dec 11, 2006 | 11:40 PM
to be honest I always thot the headlights stayed on, but when I make the brake light come on it does the same thing. When there is a quick power drain the ignition system seems to die for a second then bounces back. Sometimes it even seems to cut out and come back a couple times when i am driving. I wouldnt think it is a short or it would be more severe.
Old Dec 12, 2006 | 07:12 AM
highmilage's Avatar
try putting a volt meter across your battery terminals, this will show if you are charging properly 14 volt sor more, or not 12 volts or less
Old Dec 19, 2006 | 05:28 AM
Will the new regulator/rectifier give more hp like it claims?
Old Dec 19, 2006 | 01:13 PM
highmilage's Avatar
no more HP possibly higher amps, but you shouldn't need any more unless you are running some serious extra power using electrics ( heated grips, lights etc.)
Old Dec 19, 2006 | 08:40 PM
bosshaus1's Avatar
check your positive battery cable and make sure it isn'tshorted out,corroded, and that it is connected well
Old Dec 22, 2006 | 03:53 AM
Ok thanx for all the information. I'm gonna borrow a multimeter or buy one and check it out. And use some diagnostic steps i read about to test the charging system.
KRUSHER F3
Apr 14, 2019 08:56 AM
paul_schmd
May 8, 2010 11:09 PM
chrisrc
CBR1000F Wanted / Swap
Apr 19, 2010 03:03 AM
cbrsixpack
The Hurricane Saloon
18
Jan 9, 2010 02:18 PM
shrek
Feb 5, 2008 09:58 AM
