New Tyre
Old May 25, 2006 | 08:31 PM
  #21
MarkR's Avatar
Default RE: New Tyre
Any thoughts on whether to run 170 or 180 on the back
Thanks
Old May 26, 2006 | 12:44 PM
  #22
kilgoretrout's Avatar
Administrator - Retired
I pushed my new qualifier yesterday, and it feels great.
Old May 26, 2006 | 02:56 PM
  #23
dad's Avatar
dad
ORIGINAL: MarkR
He also said that I should run a 170 as it will improve my handling and that there are no advantages on running a 180 (except for the look).
He's right. It actually turns heavier with a 180. Fine if you don't mind moving your butt over in the seat for just about every corner at any speed beyond sloooow.
I say this as one who runs a 180 but only because of track days and the availablity of Diablo Corsa's in only 180 or 190. If it was available in a 170, I'd run that.
Old May 27, 2006 | 12:21 AM
  #24
MarkR's Avatar
I think I’ve decide, I going to put the Pilot Power on the Front and 170 Pilot Road on the Back
Old May 27, 2006 | 04:29 AM
  #25
R1000's Avatar
That is probably a good choice, please report your findings when you have covered som ground with them.
Old May 29, 2006 | 01:14 AM
  #26
Triangle's Avatar
I'm putting a pilot road 170 on the rear and will be getting a new front in a couple of months... i'll be very interested to hear what you have to say about your chosen combo MarkR - in fact, you're in my memos to contact b4 I order the front
Old May 29, 2006 | 03:45 AM
  #27
MarkR's Avatar
Still a month away, but will report back
Old May 29, 2006 | 04:39 AM
  #28
rippn's Avatar
Mark, I've heard the roads are quit abit diff. than the powers. As you say that you are going 170 rear, for handling, I think the road rear, isn't optimal.
I went w/ azaros, sp frnt, st rear, thinking I would be carying passengers... long since scared them off !!!!!!!! I went w/ the sp frnt to sharpen the turn in, and it did, but as i am solo usualy... i would go sp rear too, in retrospect( I still may!!)
I went w/ the 180 rear, and even w/ an sp rear (to match frnt turn in ), I will go w/ a 180, mostly cause i wiegh 275(almost as much as two up!!!!!) The st rear dosent seem to slow the rear unreasoably... but I'm sure it does (slow it some).Azoros, are said to "stablize" a twitchy bike, hardly a problem w/ a 1000f.
Having to "look" for twisties localy, and mostly relatively straight otherwise... is the reason I dont do the sp/sp match... just not enough curves and on the typical here, the 180st prob, is a stabilizing factor.
Talk to the power/road factory techs, they would love to get as technical, as you can use... Again I've heard the roads / powers, arn't real close in handling traits, the powers just kick butt, dry/ rain. Clean and free, Ripp'n
Old May 29, 2006 | 06:04 AM
  #29
MarkR's Avatar
So you think to go 180 Power on the Back, rippn
UK_Jase
Apr 18, 2014 12:58 PM
scorchio999
May 8, 2010 04:39 PM
cbr_jim
CBR1000F Wanted / Swap
Aug 26, 2009 02:26 AM
puma690
Aug 3, 2008 07:42 PM
Coopz
Dec 17, 2007 10:18 AM
