help seat is stuck
Old Aug 23, 2008 | 07:27 PM
87hcane's Avatar
Default help seat is stuck
well after reading the manual i dont know what happen but my seat is stuck the back of it wont come and according to the manual it just says to slide it to the rear and off it should come.
i have tried everything and it wont come off.
Old Aug 23, 2008 | 09:03 PM
MarkR's Avatar
Default RE: help seat is stuck
Are you turning the key far enough.
I change the back hand rail, and the seat lock is not as good as it was.
I might give it a bit of a DW40 spray, now you brought this up.
Old Aug 24, 2008 | 12:04 AM
pacojoseph's Avatar
Do a search. Someone else had the same problem recently. Try pushing down on the rear of the seat while turning the key.
Old Aug 24, 2008 | 04:03 AM
cookie1960's Avatar
When I got my '88, there was no key for the lock, I had to pull the cusion forward, and gently pry the mechanism back with a 8" screw driver. It damages nothing and removes the seat. Perhaps you could do this in the interum. If you need a pic, I'll try, but its off to work for the next 12 hours now.
Old Aug 24, 2008 | 05:10 AM
Coopz's Avatar
All you need is this...
Old Aug 24, 2008 | 10:49 AM
TimBucTwo's Avatar
With the key in the helmet lock turn it CCW with some mild force (be careful not to bend it) and with the left hand come down sharply on the rear of the seat. The locking catch should release and the key should turn further CCW. To remove the seat, the bake is lifted as the entire seat travels slightly rearward.
Alexanderfitu
Dec 7, 2014 05:14 AM
fescen9
Apr 29, 2013 11:58 PM
Essex Kev
Apr 27, 2011 02:12 PM
[w]
Aug 5, 2008 11:08 AM
Peedy
Aug 25, 2006 06:10 PM
