fuel pump fix
Old Feb 3, 2011 | 11:47 AM
wooferdog's Avatar
Default fuel pump fix
Hey to everybody,
Recently I wrote the "No fuel to Carbs" thread. In it, I determined that the fuel pump was indeed dead and went searching for a replacement pump. New part was $154.00 US and used anywhere from 75.00 to 125.00. Tried cross referencing to find out what other models used the same pump with limited success.
That was last November when the pump went south and during that time my search was for replacing the entire pump unit. Recently, I went back on the search and suddenly there all of these listings for replacement fuel pump points sets from K&L Supply (part # 18-4615). Googled the part number and found vendors for this part in the States and the UK. Ordered mine for $ 49.00 shipped to my door. The part is identical to the factory points and is easy to access and install. It does require soldering one lead and I recommend that you have faith in your skills since you basically have one chance to get it right.
I tested the pump on the bike and all is right again.
For a third of the price of a new pump I recommend this part.
Old Feb 3, 2011 | 11:56 AM
Indiana Hurricane's Avatar
Senior Member & 2010 ROTY
Thanks for the info wooferdog!!! I know someone that needs that info. I think you may be a lifesaver...
Old Feb 3, 2011 | 12:01 PM
wooferdog's Avatar
The google search turned up a UK vendor that has a how-to video on installing the points. When saw how simple it was, I was sold
Old Feb 3, 2011 | 12:07 PM
Talking
I sent a PM to Kiwi, hopefully he checks it out and helps him out.
This is one of the reasons I joined this site, then how friendly everone was, and I have been hooked.
Old Feb 3, 2011 | 12:18 PM
wooferdog's Avatar
Thanks Indy,
Sharing is Caring
Old Feb 3, 2011 | 10:57 PM
hawkwind's Avatar
Hey Wooferdog, glad you sorted your problem and may I also say glad you shared the solution!!
This maybe worth an entry into the alternative parts sticky
Old Feb 4, 2011 | 08:38 AM
TimBucTwo's Avatar
^ +1
Kopi Ko
Sep 6, 2024 12:02 AM
Rockshoxtora
Aug 12, 2010 03:58 PM
Fool
F4i - Wanted
May 10, 2010 02:05 PM
zblad
Dec 5, 2008 01:14 AM
