Need help (re)installing carburetors
Old Jan 27, 2011 | 07:56 PM
CaneRider's Avatar
Default Need help (re)installing carburetors
Is there trick to placing the carburetor rack back into the 4 carb ports?
I'm tried just about every method I could try.
Greasing the port sleeves.
Loosening the rack so individual carbs can move as much as possible.
Brute force , which helps the release of toxic mental energy, does
little coax the carbs correctly into position.
A few questions about this procedure in general.
Is this procedure, inherently , a two man operation?
Should/Do I need to replace the carb port boots?
Rebuilding the carbs was a walk in the park compared to this.
CaneRider
Old Jan 27, 2011 | 09:01 PM
Sprock's Avatar
warm 'em up .....the boots that is and apply
handsanitizer inside ( slipperyist **** I know ) off.
Old Jan 27, 2011 | 09:25 PM
CaneRider's Avatar
Dr. Sprock,
Thanks for the quick reply. I did try the ol' hair dryer on the port boots. What type of
"hand sanitizer" are you referring to? The Gel based stuff with alcohol? Sounds like
the general approach to this is get the most slippery substance you can find and just jam the
carb. rack back into the ports.
CaneRider
Old Jan 27, 2011 | 09:34 PM
Sprock's Avatar
that very stuff !!!!!!
ya got to move fast it drys out quick
Old Jan 28, 2011 | 01:46 AM
patricksmithahhh's Avatar
i just took off the brackets off completely and it worked fine
Old Jan 28, 2011 | 08:25 AM
6 Fingered Man's Avatar
I have had luck using a ratchet strap. Place the carbs on the boots, wrap a ratchet strap over them and around the motor, then crank it down tight, use it to apply pressure as you work the carbs into the boots. It will allow you to have even preasure on all the carbs and be able to work them back and forth with your hands at the same time.
Old Jan 29, 2011 | 01:18 PM
Sprock's Avatar
Handy when you have that extra finger to tho' eh 6 ?? lol
Old Jan 29, 2011 | 05:02 PM
TimBucTwo's Avatar
I have not done it on one of these bikes yet but other in-line 4's are a bitch too. I found it best to rotate the rear of the carbs up and then rotate the rear down while pushing them in. Basically you need to start the tops in first. They always seam to go in the easiest that way.
I have exercised my four letter word vocabulary while installing carbs in the past.
Old Jan 29, 2011 | 11:24 PM
robbiebgraham's Avatar
I'm glad I didn't have this much trouble getting mine back on as they were hanging off completely when I bought the bike.
It's great that you've got them back on now!!!
Old Jan 31, 2011 | 03:04 PM
CaneRider's Avatar
Default Thanks to all for your tips on carb. reinstalls.
Thanks to all of have given their advise and techniques for the carburerators install.
I'll let you know if I succeed in getting my silver blue 88 back on the road.
CaneRider
