Charging System Question
Old May 15, 2013 | 03:56 PM
badrhino's Avatar
Default Charging System Question
What readings should you get at the battery when the bike is running?
I have had a drained/dead battery problems since I bought the bike and am getting a reading of only 11.80 at idle and will rise to 12.6 when revved.
Old May 15, 2013 | 04:13 PM
jlpinedas's Avatar
Standard charging rate is around 13.5V+ at 3000+ RPM. At idle 12.5V but remember that the battery doesn't charge while at idle That reminds me i should charge mine as it's been sitting around my garage for a few days now.
Old May 16, 2013 | 01:11 AM
badrhino's Avatar
Should I be worried with those numbers?
Old May 16, 2013 | 10:10 AM
TimBucTwo's Avatar
Those numbers are low. Sounds like the R/R needs replacing.
Old May 16, 2013 | 11:18 AM
badrhino's Avatar
TBT, where would be the best and cheapest place to find one? Thanks!
Old May 16, 2013 | 01:21 PM
TimBucTwo's Avatar
There's some info in this LINK that may help.
This one looks like direct plug in. I believe members like Shadow have used it. LINK
I think this is the one that will NOT work. Even though its 3-phase I think its missing a wire. LINK
I used Electrosport ESR230 because its direct plug in but looks like its out of stock at their site. It looks like Ron Ayers has it.
edit: Also
Amazon Amazon
Old May 16, 2013 | 08:43 PM
jlpinedas's Avatar
+1 on Electrosport, i got that one as replacement for mine too.
Old May 17, 2013 | 03:54 AM
Shadow's Avatar
Sorry guys but if you're charging at less than 13- 13.5 V at 3000 RPM you either have a dodgy reg rec or stator (more likely the reg/rec)
My replacement reg/rec from Electrex charges anything up to 15.5V and starts at 1400RPM, 13.5 V
Replace the battery and check the charging rate - anything lower than 13V at 3000RPM you need a new reg/rec.
Old May 18, 2013 | 02:59 AM
Naga_Thai's Avatar
Originally Posted by shadow
sorry guys but if you're charging at less than 13- 13.5 v at 3000 rpm you either have a dodgy reg rec or stator (more likely the reg/rec)
my replacement reg/rec from electrex charges anything up to 15.5v and starts at 1400rpm, 13.5 v
replace the battery and check the charging rate - anything lower than 13v at 3000rpm you need a new reg/rec.
agree.....
Old Apr 9, 2014 | 01:28 AM
badrhino's Avatar
Well I put on the new Electrosport R/R and am getting readings of 12.3-12.5v at idle and above 2-3,000 it is putting out 14.5v so I think that fixed my problem. It took me a long time to finally find one of these. It is nice and heavy duty looking compared to original and it has a heat sink.
816_wallace
Sep 10, 2011 10:48 AM
89cane
Jan 17, 2009 11:31 PM
shelfrich
Jul 31, 2006 09:14 AM
Team Stevil
May 10, 2006 02:36 PM
PiMpBlueF2
Jul 15, 2005 01:54 PM
