changing clutch hydraulic fluid
Old Apr 20, 2008 | 09:26 AM
FruntRangeBkr's Avatar
Default changing clutch hydraulic fluid
My mechanic says I can replace the fluid by opening the system on the lower end and allowing gravity to do it's work while I simply pour it in at the reservior. Anybody have any thoughts on this?? I haven't even looked at the system yet...........is there a bleeder screw at the lower end?? Dot 4??
Thanks!
Old Apr 20, 2008 | 12:35 PM
Shadow's Avatar
Default RE: changing clutch hydraulic fluid
Download the manual and check it.
> http://members.iinet.net.au/~cbr/Hon...Manual.pdf>
OR
http://myweb.tiscali.co.uk/midlife/i...ice_Manual.pdf
> > Hope it helps
Old Apr 20, 2008 | 05:14 PM
Trips's Avatar
Actually I was speaking to a mechanic and he swears the best way to bleed brakes to is crack open the lines, leave it for a while (While keeping it topped up) and just let gravity work.
Old Apr 20, 2008 | 09:40 PM
DRam's Avatar
Very Honorable Most Senior Member :)
That'sthe way I've bled brakes and clutches for a long time now. Just be sure you don't let the reservoir run dry or you'll end up with more air in the line.
Old Apr 21, 2008 | 12:26 AM
CosmoBob's Avatar
ORIGINAL: Trips
I don't know, but perhaps the Dual Combined Braking System of the late generation Hurricane might be the exception to gravity doing its work?
Old Apr 21, 2008 | 12:39 AM
bluebeard's Avatar
I've always pressure bled all my vehicles. It's quick, accurate & gives the best results as you can feel what is happening as you do it. One helpful trick is to use some clear plastic tube off the end of the bleeder running into a container with a little fluid in the bottom. That way you see bubbles (air), color change (fresh fluid) & if you release the lever accidentally with the bleeder open you suck back fluid not air. I'm also usually in a hurry & refuse to wait for gravity.
subyman1440
Dec 24, 2012 06:51 AM
patches_mcmatt
Apr 7, 2011 06:31 PM
fbpsb82
Jan 30, 2010 02:23 PM
SwashBuckler
May 22, 2007 02:40 AM
malbojah
Nov 8, 2006 03:55 PM
