Cam Chain
Old Apr 16, 2006 | 04:36 PM
jetson1000's Avatar
Default Cam Chain
I was replacing my CCT this morning and I noticed that there is about 1/2" to 3/4" of slack at the top between the cam sprockets. Is this normal or should I replace the chain while I'm at it? I don't want to have to do this again to eliminate the chain noise. Also any sources on finding the chain as inexpensively as possible would be appreciated!
Old Apr 16, 2006 | 10:29 PM
Trips's Avatar
Default RE: Cam Chain
mine was like that as well. When I had rotated the engine a few time the CCT tightened it up.
P.S Whatever u do dont drop any bolts
Old Apr 17, 2006 | 11:23 AM
jetson1000's Avatar
Prior to your mishap, did you hear any improvement in the noise level from the cam chain? I turned it over a couple of times and it did tighten the chain. I'm thinking about going ahead and putting it back together and checking it out. I'm wondering how to torque the bolts holding the cam sprocket as there isn't enough room to get my torque wrench in there?
Old Apr 18, 2006 | 11:45 PM
malbojah's Avatar
ORIGINAL: jetson1000
do it the german way - goodentight
Old Apr 19, 2006 | 02:35 PM
Drake's Avatar
I tried that german method once and managed to strip one of the cam cover bolts on a previous bike. Wheeee....
Can't you get your torque wrench with an extender in there? What's in your way?
Old Apr 19, 2006 | 11:41 PM
jetson1000's Avatar
When the cam covers are in place it is a very snug fit.
davedude44
Jun 28, 2012 12:22 PM
TheHeggi
Aug 11, 2010 04:58 PM
Perranomous
Apr 19, 2009 03:04 AM
crookedeyemotocross
May 4, 2006 10:14 AM
