air fuel adjust? can it be done
Old 08-11-2008, 03:57 PM
fast1000f's Avatar
Default air fuel adjust? can it be done
is there any way to adjust the air fuel mix on my bike? the plugs are white and sounds like is starving for fuel. pump works good, no blockage, cleaned carbs, (jets, floats, bowls,slides, and carb housing).
Old 08-11-2008, 08:51 PM
Default RE: air fuel adjust? can it be done
Jet kit, and/or shim the needle. AFAIK there is no idle air adjustment. If there were, that would only effect idle and cruise to a small extent.
Old 08-11-2008, 11:03 PM
DRam's Avatar
Very Honorable Most Senior Member :)
Check yourfloat height. Specs should be in your Haynes, Clymer, or Honda manual.
Old 08-12-2008, 07:51 AM
fast1000f's Avatar
thanks i will check the float height
dyracuse
01-20-2010 05:44 PM
96strechedbackF3
08-31-2009 12:05 PM
krisko
01-25-2009 01:52 AM
itgbudeev
06-25-2008 03:48 PM
rebel3.0
07-02-2007 03:14 PM
Quick Reply: air fuel adjust? can it be done
