air fuel adjust? can it be done
Old Aug 11, 2008 | 03:57 PM
fast1000f's Avatar
Default air fuel adjust? can it be done
is there any way to adjust the air fuel mix on my bike? the plugs are white and sounds like is starving for fuel. pump works good, no blockage, cleaned carbs, (jets, floats, bowls,slides, and carb housing).
Old Aug 11, 2008 | 08:51 PM
Stray Cat's Avatar
Default RE: air fuel adjust? can it be done
Jet kit, and/or shim the needle. AFAIK there is no idle air adjustment. If there were, that would only effect idle and cruise to a small extent.
Old Aug 11, 2008 | 11:03 PM
DRam's Avatar
Very Honorable Most Senior Member :)
Check yourfloat height. Specs should be in your Haynes, Clymer, or Honda manual.
Old Aug 12, 2008 | 07:51 AM
fast1000f's Avatar
thanks i will check the float height
dyracuse
Jan 20, 2010 05:44 PM
96strechedbackF3
Aug 31, 2009 12:05 PM
krisko
Jan 25, 2009 01:52 AM
itgbudeev
Jun 25, 2008 03:48 PM
rebel3.0
Jul 2, 2007 03:14 PM
