Advice Needed. CBR1000F Shutting out at 6000 rpm
Old Dec 11, 2012 | 10:11 AM
  #31
Shadow's Avatar
its charging at a higher voltage than it should. Could this perhaps be the problem. If so how?
No, that would have no effect on your current problem. If it's charging at more than 15V I would check your regulator/rectifier as it may be about to cook your battery. Check level of water in your battery .
OK the only other issue I could suggest would be that your float levels are too low, and if you fitted bigger jets, this is possible.(but not likely)
I still believe this is a fuel/air issue and has nothing to do with the electrical system.
Clearly there's a problem with the fuel/air delivery, either too much or too little, but from here it's hard to be specific.
Do you have a big enough diameter fuel line ? If you have one that's too narrow you could get fuel starvation...................
Old Dec 12, 2012 | 08:04 AM
  #32
ranchome's Avatar
That sounds like classic float level being too low.
metropolitan
Apr 20, 2015 09:55 AM
steve.zodiac
Mar 25, 2014 09:25 PM
gemini
CBR1000F Wanted / Swap
Sep 20, 2013 04:21 AM
Mad-AL
Aug 2, 2013 07:37 PM
otr002
CBR1000F For Sale / Found
May 12, 2010 10:21 AM
