7,000rpm anomaly
Old 12-18-2005, 05:57 AM
MarkR's Avatar
Default RE: 7,000rpm anomaly
Sorry I haven’t replied.
I have had no time to doing anything in regards to this problem, There's a lot of good stuff being mentioned and I'm hope to get a little time in the next day or two to try something’s out.
I feel confident that I will be able to isolate this problem to a particular area armed with the suggestions already posted and I will post my findings in due course.
Thanks guys
  #22
Old 01-10-2006, 02:50 AM
MarkR's Avatar
I have had my first ride this year.
Got the bike out to start it as it hadn’t been started for may weeks.
I was very low on petrol, so when I stated it, I place it on the side stand to idle for a bit, after a while it coughed and died, so I guess it ran out of fuel. I read somewhere on this forum that when you turn the bike on, the electric pump runs for a few second, I also read that you have to run the starter a bit to build up a vacuum to fill the cabies, which is it?
I run the bike up to the servo to fill it, it took longer to get back as I found myself taking many detours to get home (didn’t want to get off), so I try my 7000rmp thing, still there. if I pull the clutch in and rev it, goes pass 9k no probs.
I stopped the bike and open up the fuel cap, I through of leaving it open but considered it to be a very bad idea, so I closed it zip up the block getting pass 8k no problem.
I will have to experiment with it a few more times, but 'dad' might have something there.
Is there any check I can do on the breather hose apart from the one I tried above?
RobertPaulson954
05-18-2011 01:40 PM
timb
06-24-2009 01:49 PM
rgvshane
05-07-2009 06:23 PM
fastkx125
08-23-2008 12:07 PM
89cane
04-17-2008 07:28 PM
Quick Reply: 7,000rpm anomaly
