#4 Carb is sucking too much during synchronization
Old 06-18-2010, 08:37 PM
pablohoney's Avatar
Default Need quick help with synchronization
I recently got my 1988 cbr1000 running again and I just replaced the cam chain and adjusted the valves and I am trying to sync the carbs using a manometer like this: http://members.optusnet.com.au/~macm...eterK100RS.jpg and the #4 carb is just sucking all the oil up, I have adjusted the #4 screw as much as I can and it won't equalize. Kinda out of ideas.
Thanks.
Old 06-18-2010, 10:51 PM
Sprock's Avatar
Pablo ......ya think a valve is totally outta whack on 4 ???
As in not completely seating or closing on the inlet side !
might be how you timed it up too !
Old 06-18-2010, 11:48 PM
kilgoretrout's Avatar
Administrator - Retired
Interesting.
Maybe try turning the idle up and #4 down?
Old 06-19-2010, 09:48 AM
pablohoney's Avatar
I triple checked the valves, so I don't think that it is that, and the timing.
The problem is that the adjuster screw is about a turn from falling out in the present state that it is in.
Cbrclassic my be right, I adjusted the float levels then it started doing it. That could do it?
Old 06-20-2010, 01:38 AM
Shadow's Avatar
AHA ! I seem to recall someone else doing this and having a similar problem. Return the float levels to their original positions and all should be at least a lot better. There's a post on this somewhere..............
Old 06-20-2010, 11:04 AM
TimBucTwo's Avatar
If that is the case, #4 is closed to much and the other three need to be opened more. You will need to get #4 closer to the base carb and then bring the other two in.
Old 06-21-2010, 12:12 AM
pablohoney's Avatar
The problem Timbuctwo is that you have to adjust the other carbs to match#2. You can't adjust it on my model and I can't adjust #4 anymore.
Thanks shadow, I'll search for it.
Old 06-21-2010, 11:29 AM
pablohoney's Avatar
Problem solved. Turns out that the spring in between the adjusters was all messed up on the number 4 carb. Ha. Thanks guys.
pablohoney
The Hurricane Saloon
07-14-2010 03:10 PM
tahoetob
09-01-2009 05:12 PM
victory211
06-09-2008 04:32 PM
AudiCBR
07-02-2007 09:08 AM
dunedude
10-11-2006 07:35 PM
Quick Reply: #4 Carb is sucking too much during synchronization
