Sucking up Gas
Sucking up Gas
I just traded a bike for a CBR600F4i 2002 The bike is very stron and fast it has a major issue though we fill it up and run out of gas in about 70+ miles or so the bike smell very rich and it fouls the plugs and will drop a cylinder if you arn't clearing it out . We just synced the carbs and set the valves it still is going through gas like there is no tomarrow??? Need help pls
Sorry the throtle bodys were synced. It runs goood except for a sputter around 8k then zoom it cleans up and runs awesome but it is only getting 70+ miles on a tank. The MIL is not picking up any malfunctions or problems. It has a short D&D pipe no air intakes hooked to the front cowl and no power commander. Would the MIL detect a faulty fuel presure reg??
No, The fpr diaphram ruptures and backfeeds into the cylinders via vac lines. The MIL system doesnt monitor that at all. Pull the vacuum line from the fpr to the 3way connector and you will most likely have gas leaking there. Then you will know for sure.
