Sucking or blowing
Old Oct 9, 2006 | 08:38 PM
dunedude's Avatar
Default Sucking or blowing
Now that I have your attention...
Every time I open my gas tank I have either positive or negative pressure (sucking or blowing). Is this normal? Is the tank vented? Perhaps through the cap?
Old Oct 9, 2006 | 11:50 PM
dwhite645's Avatar
Default RE: Sucking or blowing
Hmmm, it should be vented through the overflow hose that goes out the bottom (1 of 3 hoses). Never heard that on mine unless your hose is plugged up.
Old Oct 10, 2006 | 01:34 PM
Tahoe SC's Avatar
yea mang...check your hoses...pull the tank and check to make sure it's not crimped or blocked...why? because in due time, the pressure will cause the tank to bulge out or dent!
Old Oct 10, 2006 | 03:11 PM
FATHEADS1KRR's Avatar
EPA doesn't allow direct tank venting. The overflow serves the area around the filler neck. Is perfectly normal to have vacuum/pressure in the tank. You guys have to have heard this from your cars too ?
The tank is "vented" but only after a certain psi, like a radiator cap.
Old Oct 10, 2006 | 04:08 PM
Tahoe SC's Avatar
hey fats...yes, the overflow is above the filler neck line and comes out...so not truly 'open' but what he's describing is a bit too much...it should be so much to be totally noticeable as he describes.
Old Oct 10, 2006 | 04:57 PM
I don't know how much is too much to him or you, but w/where he is from, BIG temp swings can cause what he seems to be describing. 60 dergee temp swings and triple dig highs are both causes for a lil tank vac/pressure. Most e/thing newer than about 90 have had what i would consider a sealed tank. There is alway a vent, but some pressure or vacuum is normal. He also stated that it changes from pres/vac which makes me think its normal. I hear it all the time from customers. What i meant about the overflow tube is that its "outside " of the tank itself. Drains overflow, is not a vent.
Old Oct 10, 2006 | 11:24 PM
dunedude's Avatar
Thanks for the feedback!
Actually the pressure HAS caused the tank to dent. I spoke in a previous post that I had dents that had begun to leak fuel and I think the reason is from this pressure.
I have been told, by a Honda dealer service rep. that the gas tank vents through the cap and so I have ordered a new one. I hope that this fixes the problem. The price for a new honda cap is around $150. [:@]
Old Oct 11, 2006 | 11:31 AM
WOW !! Takes a LOT of pressure to dent the tank ! I had not read that post ! Yea a new cap sounds like a good idea !! My 02 f4i would vent pres/vac when opened, but no denting. Maybe the cap was going bad on it too !?
Old Oct 11, 2006 | 01:15 PM
Tahoe SC's Avatar
maybe he has your old F4i FATHEAD? hahahah...
i guess it vents through the cap, but not out from the to of the cap, but rather, downwards through the overflow eh?
Old Oct 11, 2006 | 07:35 PM
Maybe !! I'm gonna side step outta this one now.... since my advice was WAY off !! [sm=oopssign.gif]
hmm
May 8, 2012 07:57 AM
Samuel Petrasca
Feb 21, 2012 02:37 PM
pablohoney
Jun 21, 2010 11:29 AM
tahoetob
Sep 1, 2009 05:12 PM
