keep blowing the same fuse :(
Old Feb 20, 2012 | 03:03 PM
Samuel Petrasca's Avatar
Default keep blowing the same fuse :(
my r/r and battery both went bust a month ago, since then iv been hooking up a battery jumper thing to the terminals every week or so and just starting it up and letting it idle for a little while. the other day i finnaly got another battery, when i hooked it up though stupid me put it on backwards (which might have blown the fuse, maybe maybe not) when i put it back right and turned the key nothing. so i called it a day. today i went out to try again, i found the fuse (its the green 30 at the plug where the positive wire for the battery goes back) unhooked the battery, put a new fuse in, then hooked the battery up again, and it blew immediately. so i figured maybe it doesent liek the battery and ill just do it the way i was doing it before. so i put a new fuse in then put the old battery back on and hooked up the battery jumper to it, fuse blew immediately again. i went through 2 more fuses trying so now im readr to ask for help
1992 cbr600, i still have the old broken r/r on it cause ebay is taking forever
Old Feb 20, 2012 | 07:46 PM
filthydanger's Avatar
i had this problem. that fuse kinda goes to everything on the bike though. so i could be just about anything... when i changed my starter relay switch (what the fuse is in) it stopped for me....i used one off of a GSXR, along with the r/r and works fine...they talk more about it on some other threads on this site... the manual might help you too...Honda CBR 600 F2 Shop Manual - Go Fast Video where i found mine and it works fine...
Old Feb 20, 2012 | 09:01 PM
sjona2011's Avatar
the battery jumper is probably putting too much current through it.
try charging the battery normally, if it still doesnt work then you more than likely have a short somewhere, in which you should break out the DMM(digital multimeter) and troubleshoot...or look the bike over for any loose wire.
sjona2011's Avatar
Old Feb 21, 2012 | 10:39 AM
underground-mpyre's Avatar
I agree with filthy danger. Start with replacing the starter relay, more than likely bad causing the fuse to pop. If you do not hear a click when trying to start it and the fuse blew, it is the relay.
Try connecting a postitive wire to the starter and connect a negative wire from the frame to the starter, should spin the starter. The battery should be sufficient.
Old Feb 21, 2012 | 02:37 PM
tomtom's Avatar
Default blow in same fuse
i have just changed my R/R and i didn't disconnect the battery when i plugged it in so i disconnected the R/R and the bike was starting up like normal so there's something wrong with my wiring or a faulty R/R. so did you buy a new R/R? and if you did try unplugging it. hope this helps
kyle377
Jul 17, 2012 09:28 PM
craig wilson
Apr 20, 2007 03:49 PM
craig wilson
Apr 19, 2007 11:52 PM
Kappa2006
Apr 18, 2007 01:02 AM
Bibdrums
Aug 8, 2006 09:42 PM
