F3 frame with new RR FI motor
is this possible? im getting in pretty deep on this 95 F3 project, i want to do a frame off build with a fork and swingarm swap, and a newer 600rr fi motor. anyone ever attempted this? i know of a 07' 600rr motor for a killer price. complete from airbox to ecu and harness. all hand controls, everything. is the steel F3 frame up to the task? any issues people are aware of? any input would be appriciated
anyone? im trying to think of issues before i even touch my bike.
1)dimensions of the new motor, similar shape?!? frame clearance, similar mounting points?!?
2)sprocket alignment (if i have to use the F3 swinger, if the rr swinger isnt possible)
3) electrical harness routing, mounting of components, etc.
4) fuel system, (i dont think it comes with a fuel pump, i'll need a RR one, or one that can support FI
this is just a little brainstorm, im gonna need some input from you guys, just kinda thinking outloud to the forum (my girls not too enthusiastic).
any thoughts?
any thoughts?
Seems to me if you're gonna go through all the trouble collecting RR parts, you might as well add an RR frame and skip all the cutting / fab / welding hassle.
Or buy the RR kit. Honda even preassembles it for you
it does seem like a lot of work, but its not fabrication that im afraid of. i did fabricate tubular structures and machine tooling for an engineering firm for two stressful years.
its still an inline 4, so how different could the mounting points be? i wish i could see one to see how they mount. anyone have a side view showing the motor mounts? im just thinking about it, im curious.
Mouting points could be very different. Just because its a four cylinder doesn't mean its the same. For example. Look at a k-series honda motor vs. a b-series. They both essentially go in a civic but they are NOT easily interchangeable.
That's my point exactly. When b series swaps got huge in the mid 90s, people were thinking k swaps were never going to be possible for the average guy. Now they are putting k20a's in every civic made. Simple mount kits. Bolt on kits to easily put a motor in a chassis that was never designed for it. So my point it that probably could be done. Crazier **** has been done.
Will it fit in the frame for a start? I rekon so, i've seen a 900RR engine in one, You will need to remake ALL of the mounts, the sideones are easy enough there just triangle mounts youll need to machine, but its gunna require cutting the front ones off and the ones near the swingarm and remaking them all together.
Will it take alot of time? Yes, so youll need other transport whilst doing it.
Will the frame hold up? i rekon so again ive seen one with a 900RR engine hold up, but it wouldnt hurt to reinforce it a bit more would it?
I imagine the sprockets would line up.
I think pretty much all FI bikes have the fuelpump in the tanks so youll need a new tank i rekon not sure were the CBR RRs have them.
The wireing loom would have to go alltogether and replace it with the RR one.
But if youve got the skills, Money and Time to do it then i say go for it, post up loads of pics and bring it to the UK and let me have a go on it when its done lol
My plan this winter comeing is to get my self another road bike *COUGH* New Blade *COUGH* that will stay standad, Keep my F3 as a show and drga bike stick a 900RR engine in my F3, bore it out to a 1100 if possible, Reinforce everything then ATTEMPT to get it to pass Road safety tests to get it back on the road but no biggy if it doesnt pass road saftey a drag and show bike she shall be.
Then turbo the engine in summer 2011 or winter 2011 depending on money.
I see what you did there lol.
