Sprocket wear issue
Old May 30, 2008 | 02:34 PM
Stockrocket's Avatar
Default Sprocket wear issue
Sup, running a 520 +5 teeth rear sprocket and it seems to be wearing down fast as hell... Its the lightweight aluminum, same as my last one and the one that is on my bike now isnt even 1000 miles old and is lookin pretty wore out? Anything that could be contributing to extra wear on the sprocket that I can look into and possibly fix? Any help would be sweet...
Stockrocket/Richard
Old May 30, 2008 | 02:43 PM
bindelsf2's Avatar
Default RE: Sprocket wear issue
too tight of chain, too loose of chainand wheelies...
Old May 30, 2008 | 06:45 PM
be vertical's Avatar
Not enough lube Id say. Aluminum does not like it when a harder metal rubs on as it is much softer. That in combo with too much torque on the wheel (+5 will add a lot) will chew up a sprocket.
Old May 30, 2008 | 07:04 PM
So when I replace this one I should just go with the steal sprocket so I donthave to replace it after a couple months?
Old May 30, 2008 | 08:22 PM
heybuddy1901's Avatar
yes, steel will last alot longer.
just ask yourself if repalcing the alum. sprocket every couple months is worth the slight weight savings/added cost
Dragondima
Feb 28, 2011 02:47 PM
vrodhdtjt
Apr 1, 2010 11:10 PM
vrodhdtjt
Apr 1, 2010 08:32 PM
kappa
Oct 2, 2007 08:30 PM
Slowestcbr
Jul 20, 2007 10:33 AM
