Need more power
Old Jun 14, 2006 | 07:16 PM
snowrider's Avatar
Default Need more power
I have a 03 600 rr that i would like to be able to lift the front tire with little or no effort. Im not that big only 140 LBS so there is just not enough to through around.
Old Jun 14, 2006 | 07:26 PM
JAY 2002CBR's Avatar
Default RE: Need more power
Look into changing your gearing (sprocket size). Do a search, plenty of info on this subject.
Old Jun 18, 2006 | 03:30 PM
larry600's Avatar
most go -1 front +2 rear thats what i'm doing when the parts come in that should do the trick for you i have a 2004 cbr 600 f4i with 900 miles on it i put a k&n air filter and a yoshi slip on, on the bike just need the sprockets then i will get some sort of a power commander
Old Jun 19, 2006 | 04:00 PM
Tahoe SC's Avatar
at 140...the front should be lifting already at full WOT...
on/off method will also get the front off the ground.
you just tneed to 'learn' and know the bike some more and know where the power is at.
Old Jun 21, 2006 | 01:23 AM
kaynott's Avatar
try ignition advancement. Search this site there is pretty good info on it. That is my next project
coolbluedab
Feb 7, 2014 07:13 PM
romanboy
Jan 19, 2013 12:53 AM
__Z__
Jul 14, 2010 10:00 AM
Karmakazi
Sep 29, 2009 09:58 AM
Certified Ryder
Nov 12, 2007 10:13 PM
