Dyno and Heat Sheild - '08 CBR600RR
Old Aug 8, 2008 | 12:43 PM
FunHog53's Avatar
Default Dyno and Heat Sheild - '08 CBR600RR
Just put a PC III in last weekend and downloaded the Akrapovic map from the site. I've heard that because theonline maps are generated in Las Vegas, NVand their gas and elevation is way different from CA, the maps are not ideal. My question is -performance wise I only have a slip on Akrapovic exhaust - do you think spending $300 for a Dyno tune would be worth it?
Also, I modified the heat shield under the tail soit wouldn’t show when I removed some of the back fender. Can Iremovethe entire heat shield? Will that affect the plastics underneath?
Old Aug 9, 2008 | 02:30 AM
gotobatter's Avatar
Default RE: Dyno and Heat Sheild - '08 CBR600RR
regarding the heat shield, your going to hear mixed opinions, but i feel the heat shield should be entact....
Old Aug 12, 2008 | 10:57 PM
Xuracing's Avatar
Well as long as your *** doesnt catch on fire i dont see a problem its mostly personal preference the plastic will frey faster with out the sheild though
Old Sep 5, 2008 | 10:56 PM
white99gt's Avatar
ORIGINAL: FunHog53
YES..
THe peak power may not change much..But the lower throttle areas is where you will see the biggest difference. I rode on a dl map for awhile,then went to a friends custom map,then finally dyno tuned mine.. Air/fuel was pretty much the same,but the throttle response is night and day esp down low.
Heat shield -no help there.
Frost
Apr 12, 2013 09:50 PM
Dr.Fingers
Jul 27, 2008 06:55 PM
bamzo25
Mar 1, 2008 01:10 AM
ctskydive
Sep 15, 2007 12:27 AM
C4
Apr 29, 2007 05:11 PM
