installing pc3
Old Apr 14, 2007 | 11:16 PM
CBR55's Avatar
Default installing pc3
Hi, I'm having trouble installing the pc3. Does anybody know where i could find a picture diagram? i plugged everything in the bike won't start.
Old Apr 14, 2007 | 11:21 PM
doncollins's Avatar
Retired Administrator
Default RE: installing pc3
Are you sure everything is plugged in? I've hooked up a couple of them and it's pretty straight forward install.... so I'm wondering, are you sure the wires for the PC 3 itself are getting a good connection? It's been over a year since I did the installs, so help me out, you have to run a wire to your battery, is it getting a good connection? The rest should sanp in so it's hard to mess those up.
Old Apr 15, 2007 | 02:56 AM
de goose man's Avatar
have you seen my set up, I posted a pix by pix/step by step install.
did you hook up the TPS connectors to the right spot, make sure its not the one in the middle of the throttle bodies, because its an exact fit. the tps is on the left hard to reach.
Old Apr 15, 2007 | 03:13 AM
CBR55's Avatar
thanks you for info. everything is work in working order, had a littl emix up
Old Apr 15, 2007 | 03:43 AM
doncollins's Avatar
care to share the mix up?
Old Apr 15, 2007 | 12:42 PM
CBR55's Avatar
had a wire mix up, the one going to throttle body
Old Apr 15, 2007 | 12:48 PM
doncollins's Avatar
The throttle position switch?
lillon
Mar 2, 2011 10:50 AM
rideoncbr
May 27, 2010 03:49 PM
llamonica21
May 20, 2010 02:03 AM
chpsk8er630
Jun 16, 2007 12:55 PM
skimo0104
Dec 29, 2006 12:03 AM
