installing pc3
Hi, I'm having trouble installing the pc3. Does anybody know where i could find a picture diagram? i plugged everything in the bike won't start.
RE: installing pc3
Are you sure everything is plugged in? I've hooked up a couple of them and it's pretty straight forward install.... so I'm wondering, are you sure the wires for the PC 3 itself are getting a good connection? It's been over a year since I did the installs, so help me out, you have to run a wire to your battery, is it getting a good connection? The rest should sanp in so it's hard to mess those up.
RE: installing pc3
have you seen my set up, I posted a pix by pix/step by step install.
did you hook up the TPS connectors to the right spot, make sure its not the one in the middle of the throttle bodies, because its an exact fit. the tps is on the left hard to reach. |
RE: installing pc3
thanks you for info. everything is work in working order, had a littl emix up
RE: installing pc3
care to share the mix up?
RE: installing pc3
had a wire mix up, the one going to throttle body
RE: installing pc3
The throttle position switch?
