HESD adjustments
Old Sep 3, 2007 | 12:06 AM
CBR1000's Avatar
Default HESD adjustments
Is it possible to make any adjustments to the factory HESD on an '06 1000RR? I'm curious because I've heard of people changing out the oil in the factory Suzuki's damper to give them a better feel. Since the Honda damper is electronic I imagine adjustments are possible, but more technical than just changing oil grades? I would like for it to feel a little tighter, not as much play while downshifting and coming to a stop. I assume changing out the damper would improve things, but I didn't know ifthe factory unit isadjustable at all. Thanks in advance for any advice.
Old Sep 3, 2007 | 05:33 AM
DrDRFT's Avatar
Default RE: HESD adjustments
I have heard that the only way to change the adjustments on the original HESD, is to get a HRC computer(replace your orig). and then you need a special cable of some sort...I too want to keep the HESD on my 06' too,but have yet to look into the HRC computer... But will probably do it very soon...
Old Sep 3, 2007 | 08:42 PM
1fasthonda's Avatar
No adjustment possible!
Old Sep 3, 2007 | 09:17 PM
MgA_ODEN's Avatar
ORIGINAL: 1fasthonda
That would be incorrect .
If you purchase a Dan Kyle/HRC ECU , the software & cable available at an added expense to reprogram certain functions of the ECU then you can turn the HESD off/on as well as setting the damping levels on a scale of 1-10 for both constant speed & acceleration.
Old Sep 4, 2007 | 07:43 AM
baxsom's Avatar
yep
the hrc ecu as well as the accompanying cable can adjust the hesd but it is very expensive
it is cheaper to get the ohlins or gpr
sacbr1000rr
Oct 16, 2008 06:48 PM
birde
Oct 30, 2007 06:56 PM
dwhite645
Jul 15, 2007 10:37 PM
TexasCBR1000RR
Jun 12, 2007 02:46 PM
dizzie56
Nov 14, 2006 10:34 PM
