HESD Question
Old Oct 28, 2006 | 03:27 PM
dizzie56's Avatar
Default HESD Question
Does n e body know a way to check if the hesd is off a lil?
Old Oct 29, 2006 | 01:40 AM
2wheels's Avatar
Default RE: HESD Question
I am not sure I am understanding your question, but are you asking how a person can check to see if the HESD is off? If this is your question, I believe the answer is: The HESD never goes off. You don't want it to go off. It is the 1000rr's steering damper system. When you turn your key to start your bike, you should see "HESD" light up on your information panel. As far as I know, this means the damping system is working.
Old Oct 29, 2006 | 02:03 AM
Sparkie's Avatar
I think, he meant to ask if there is a way to check if his HESD is not functioning properly, has a misalligmnet or something(don't know if this possible thought).
Old Nov 13, 2006 | 11:53 PM
raredogg's Avatar
if your hesd is not working the hesd will be displayed on the instrament cluster
Old Nov 14, 2006 | 12:36 AM
hobbs51's Avatar
if i am not mistaken the manual says to get the bike on a front stand put the bike out of gear rev to 3k to see if the steering tightens up their was a down load of the manual on this forum i will do some checking on that i have the manual on disc somewhere.
Old Nov 14, 2006 | 12:58 AM
baxsom's Avatar
HESD test per the manual
Test procedure is as follows..
Raise and support the front of the bike. Move the steering back and forth several times to get a "feel" for minimum damping.
1. Lower the side stand
2. Shift tranny into a gear other than neutral.
3. Open the throttle fully ( WFO ).
4. Turn the ignition switch on ( don't start the engine ) while maintaining steps 1-3.
The HESD icon on the LCD display should start blinking ( If not, start over ).
For the next 10 seconds, the ECM will set the HESD to maximum damping ( full-stiff ). Compare this to minimum damping. If there is no change, replace the HESD unit.
NOTE: This test will not work if the Malfunction Indicator Lamp has indicated a problem exists in the PGM-DSFI ( MIL is flashing ).
Also note: Some moto-mags have implied that the HESD provides no damping when it's "off". This is not true! Unless the HESD unit is damaged ( IE-no oil, etc ), it always provides a small amount of damping, even with the key off.
Old Nov 14, 2006 | 10:05 PM
hobbs51's Avatar
thanks baxsom for the correction i wasnt sure the manual has it all
Old Nov 14, 2006 | 10:34 PM
baxsom's Avatar
no prob
i dont have a way to lift the wheel off the ground by the triple tree yet to try it so someone please let us know if it works
sacbr1000rr
Oct 16, 2008 06:48 PM
firefighter110a
Mar 15, 2008 11:22 PM
dwhite645
Jul 15, 2007 10:37 PM
TexasCBR1000RR
Jun 12, 2007 02:46 PM
Jet Jockey Z06 Vette
May 15, 2007 08:44 PM
