problem with my f2
Old Jul 17, 2007 | 11:31 AM
MikeInCtown's Avatar
Default RE: problem with my f2
Mine will only "deisel" when I start it back up after it's warm and been sitting for 5-10 minutes. When cold it makes no noise. It will only make the noise when warm for maybe 30 seconds or so and then I believe the oil gets in there and makes the tensioner do it's job. Well, at least I hope it's only the tensioner becuase that's one of the next repairs, and if that doesn't help, then I'll be doing valves, springs, and rockers this winter.
Old Jul 17, 2007 | 11:38 AM
600f2supersport's Avatar
now that you say that, it does the same to me, only after its been restarted when its been warmed up already. starting up cold its usually ok. except for i generally have problems getting it started without rolling on the throttly. even with the choke on, ive been told your not supposed to give it throttle with the choke on. but it wont start otherwise. so i usually try to start it with the choke twice, if it wont, then i hit the starter button and roll on the throttle fer a sec to start it then let it warm up. it likes to warm up at 3k rpm when i start it with the throttle tho opposed to the normal 2k rpm without using the throttle to help start it...
Old Jul 17, 2007 | 01:30 PM
dwalker4907's Avatar
mine is the same way....if im tryin to park ina specific spot and end up killing it and restarting it after a ride to get in the right spot then it diesels on me...but i dont think it sounds like big problem...i dunno though...guess ill let you guys figure it out!
kwood
Jun 1, 2020 09:53 AM
hatchtegman
Sep 1, 2010 03:15 PM
vietladin
Dec 25, 2007 09:48 AM
dewthedoo05
Sep 4, 2007 09:32 PM
Trips
Nov 26, 2006 01:45 AM
