Ignition advance rotor...
Old 03-13-2009, 09:20 PM
f3BikeR's Avatar
Arrow Ignition advance rotor...
So where does it install? Near the pulse generator and clutch assembly I imagine. I ask because I wonder how much work it is to get to one if an adjustable is to be installed.
Old 03-14-2009, 07:41 AM
It's located on the right side of the engine. It's bolted directly to the end of the crankshaft. It's easy to get to. After removing the right lower fairing, you would remove the "Pulser Cover" which has about 6 or 8 bolts holding it on. This is a photo of it with the inspection cap removed. You can't get it out through this opening, you must remove the larger cover.
Old 03-14-2009, 11:30 PM
f3BikeR's Avatar
Thank you! So is the 'larger cover' the clutch cover?
Old 03-15-2009, 08:20 AM
The larger cover I'm referring to is item #1 here. Not the larger cover where the clutch cable is attached.
Old 04-14-2009, 11:42 AM
f3BikeR's Avatar
Wink
Will i need to purchase part #4 (gasket) if I am to remove the larger cover off?
And I read in some places that ignition advancers will help out your top end only, and other places mention that it only helps low end/midrange.
So which is it?
Old 04-14-2009, 01:56 PM
jjennings153's Avatar
i put an advance rotor in my bike i went easy didnt need a new gasket. i noticed a little more pep on the bottom thants about it really.
Old 04-14-2009, 03:18 PM
Rickracer's Avatar
An ignition advancer should help everywhere BUT the very top end, although it may help there too. But it won't be huge, mostly just better driveability.
Old 04-14-2009, 05:06 PM
b.haley's Avatar
so you would fell the difference? ive been wanting to do some "go faster" things to my bike but dont wanna waste money
Old 04-14-2009, 06:08 PM
Default advane rotor
its worth it, you will feel a diffrence for 60 bucks you cant go wrong really.
Old 04-15-2009, 07:17 AM
wussola's Avatar
I believe that adding an advancer will effect your low or high end depending if you go positive or negative. I installed a +2 adv in my CBR. I definitely noticed more pull on the lower end. Also (for what it's worth), the engine feels different at similar RPMs (less vibration) and the exhaust makes a different tone. It took me a little while to get accustomed to engine feel vs speed.
Would recommend the mod.
ajzcamaro
03-13-2012 10:26 AM
cbreric
04-07-2009 09:30 PM
s1rusdvirus
09-02-2008 09:51 AM
89cane
02-14-2008 05:20 PM
Quick Reply: Ignition advance rotor...
